So ...
My Saturday morning started with jacking the car up.
i had a sortex 2.5 inc pipe,
3 updated exhaust mounts, a standard triangular mount,
and exhaust assembly paste.
So as I started to spray and brush the bolts holding the back box on. I attempted to un-do the bolts.
the flange had completely rusted out and crumbled to dust !
because it crumbled it was free to remove the back box.
Next was the other end ......
The nutts had rusted to a kinda odd lump. / there are no bolts on the cat they are welded studding)
so I removed the pipe from the next break which was just under the manifold.+ Un-clipping the sensors to free the pipe completely
Pipe removed!!
Now to split the cat from the b-pipe . I cut the nuts / studs straight off with a grinder ( cutting disc used)
they fell apart from each other easy. But now I have a cat with no threads to bolt it together again.
i cut the other end of the bolts/studding as the were welded to the cat, the. Drilled them out.
Ready for re-assemble
put new rubbers on back box and fitted to hangers on the car . Then the triangular mount and sportex pipe put in place. Abit of paste and bolted together nicely.
Then put a new mount on the cat hanger and hanged in place.
1st I bolted cat to the manifold (to get it into place) them the cat to the sportex pipe
useing suitable bolts to replace the studs I drilled out.
Job done !! - (what should of took an hour for me turned into a day, had to be done as need the car for work)
Now ...
I would like new spring bolts for the back box without being ripped off so please let me no were to get them???
In my option - when the car is parked on a flat road there isn't really a massive ground clearance from the floor to the sportex pipe, so does anyone have any photos of there's they can show me ??
Thanks for reading
Ash
(Thread has been posted on I-phone so I apologise for spellings
or strange lay-out/ mistakes)
Pipe removed!!
Now ...
Thanks for reading
Ash
