I've just taken my car in (As its still under extended Warrenty from the dealership). My problems were as follow's (The Car is still at the Garage);
Suspension / nearside dash / near side front wing
Clicking noise, seems to be coming from the nearside suspension, although I can’t pin point where the noise is coming from, I’ve done some research, with a mixed response. Some say that this could be a bush? CV joint needs lubricating, or also, and the more likely is the Body Seem needs separating? This could also be a Build up of dirt between the two sections of the vehicle sub frame. This causes the two sections to ‘stick-slip’ under the application of braking or acceleration forces / bumps in the road.
Honda Response:
Can't recreate the noise... No problem / no cure.
High pitch, vibration when hitting the end of the V tec (7,000 RPM) / Passenger window
Owning many Type R’s, I am aware of the noise that they produce while hitting the VTEC. The noise in my car has altered over the past month or 2, and now makes a louder vibrating noise in 3rd when hitting the vtec at around 7,000 RPM (just before you change gear). It sounds like something is vibrating near the passengers window.
Honda Response:
Clutch Noise
There is a noise coming from the clutch, only when at biting point in 1st gear (2-3mph). This can really be heard best going at very low speeds, with the clutch held at a biting point. Defo a Chewbacca type Noise, maybe slightly worse when cold, but I am positive it happens even when warm.
Honda Response:
Honda UK are aware of the problem, but no Fix available? My question is: How long does it take to create a fix? If a fix becomes available, after my Warrenty has expired, then what rights have I got to get my Clutch sorted with the Fix?
Locating 3rd Gear from Cold / Gear Pop’s out.
Quite often, the gear will pop out of gear, just as I have changed into 3rd, occasionally grinds.
Honda Response:
Can't recreate the problem... No problem / no cure. (Although I am fairly certain this is a common fault, The transmission has a faulty 3rd gear synchronizer or 3-4 shift sleeve. CORRECTIVE ACTION Replace the 3rd gear set. Failed Part: P/N 23444-PNS-306 H/C 7407042 Defect Code: 03214 Symptom Code: 04101
Can anyone help with anything that I can give to the dealer to try and correct these problem. Most of the problems are noise related, and don't happen every time I sit in the car (Apart from the clutch and vibration noise). Do they have to recreate the problem in the Garage, can they not just go on what I have told them?
HELP PLEASE!
Honda Response:
Honda Response:
Clutch Noise
Honda Response:
Honda Response:
HELP PLEASE!
