Just installed this. And it does make a noticeable difference! I would say the throw is about a quarter less (or even more (if you know what I mean)) in each gear. Excellent mod. I would recommend it to anyone.
One piece of advice to anyone installing this. Get a spool of string and tie it to everything that you are touching - the spanner, the screws, the piece of plating of the short shift kit and especially the hex key used to turn the screws in. I dropped the hex key three times :shock: and luckily it was attached to the string or it would have gone down the black hole that is the console. I dropped the short shift kit plating once. :evil: Luckily, I managed not to drop any screws as I only coiled the string onto them instead of tying a knot.
Also, I found that it was hard to get short shift kit to "slide" into place. I had to use a wrench plier like this to force it into place:
Can anyone tell me whether their kit plating was a perfect fit? Mine seemed not to be able to sit flush against the main kit piece at the gear stick end as the gear stick is a bit too wide.
good tip... I was dropping nuts, bolts, screwdrivers down the engine bay installing my icebox... had to jolt the car several times to get it to fall out!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
