Okay... next step
Oxygen Sensor Bank 1 Sensor 1 Sensor High Voltage
edit: bank 1 = pre cat, the AF O2
that code mostly is the result of air fuel screw up...
Running too rich...
Where and when did you get a remap?
Be careful with this one, this might be bad! Don't want to scare you but it could cause damage to various components. My mate flooded his O2 sensor twice by a rich mixture on his mitsu, cost him quite a bit...
Before getting too exited (in a negative manner).. Do the old fashion checklist...
Are your sparkplugs black and/or wet?
Is there liquid in the exhaust?
An AF failure is often the cause of a sensor failure, and there are many... (map, O2, temp, knock...)
A bad sensor providing bad info results in an ECU doing bad stuff as well.
Note: I am no expert at all, just trying some rational steps in helping you sorting this out.
It might as well be a flat tire causing this (in a manner of speaking)
