£60 off eBay.
Again tegiwa do one.
The reason I ask is because the RBC is bigger and will put strain on the oem inlet pipe.
The sfs hose is easily trimmed, and more robust - it also looks better
The oem inlet pipe may not even fit with the RBC now I think about it.
I am using an upgraded 70mm throttle body but I took off the inlet hose to try it on the throttle body and it fits (a bit of a squeeze). Should be fine temporarily till I get my SFS hose.Are you using the OEM throttle body? It will fit fine if that's the case, if you have upgraded to a 70mm throttle body it will be a bit of a stretch
