Hi guys
I'm looking at changing me rear brake discs as they are starting to corrode and sound like they are rubbing a little too. I was just wondering whether its worth spending the money on OEM discs since I think they are pretty expensive at £55 a pop.
If I dont use OEM which others would you guys recommend? I don't use it for the track at all BTW. I'm also I bit unsure about mixing makes, since the fronts are fine and are OEM's at the moment.
Plus I was told that if you are changing the discs you might as well change the pads too and since they are the rears, again, is it worth using OEM pads or should I just go for mintex or something?
I was also wondering are you supposed to change the fronts at the same time? (which were changed not so long ago anyway).
Any advice would be much appreciated!
