Right chaps, I need to call upon the vast amount of collective knowledge available on this fine site. (I've had a search and haven't found what I'm looking for :lol
Bhasically,
As some of you may or may not know, I recently fitted an excellent Wilwood brake setup to my car. Banging.
As a result of fitting these bigger brakes, I now have to run 5mm wheel spacers to clear (juuust) the calipers. A downside to these spacers is that my wheels are now no longer hubcentric as hubcentric 5mm spacers do not exist and are physically impossible to manufacture so I am now suffering from very slight wheel wobble at motorway speed that gets worse at "higher" speeds. Plus I feel that this setup is weak and if too much stress was somehow put into it whether it be a pothle or whatever, then this would be the point of failure and my wheels would fall off
The two main routes or remedying this horror is to either fit bigger hubcentric spacers that would require extended wheels studs which (so I have been assured) requires new wheel bearings to be fitted as the old ones need to come off and cannot be put back on again. This route is hella $$$ plus I really can't afford to have the car in at a garage at the moment as it is my daily drive and I cannot realistically get an alternative way into/back from work.
The other route that occured to me in a desktop daydream today is to fit aftermarket wheels that have sufficient negative(?) offset to negate the need for spacers and can clear the calipers on their own, then this would be a more pleasing and easy alternative.
Now I am a total noob when it comes to wheels and have only in the past 5 minutes learnt what wheel offset actually is. So I just thought I'd get some expert opinions on whether or not this is actually feasable or not. Even if I could get wheels with just slightly more offset than my OEM's, so that I could run 3mm (if they exist) spacers and the lip on the hub could catch the wheel centre therefore holding it concentrically.
I'm sorry if that makes no sense at all guys, it was written on the fly and in a hurry.
Cheers for reading chaps, all input welcome!
Y'all stay classy now
Bhasically,
