Suspension Setup
Hi guys, I have a type r ep3 and i have a set of 30mm eibach springs to go on. I was wondering if i could use them on the factory alignment settings for a few months until i get my camber adjusters or wait till i have the camber kit ?
I will be getting the rear ARB and rear control arms when i buy the camber kit and get it all done at the same time.
Also when i get my camber kit are these settings fine for just a road set up
1 deg negative camber all round.
0.5mm toe in at the back
0.5mm toe out at the front
I'd wait and get it done at the same time. The EP3 has MacPherson struts so lowering the car will affect the geometry.
you would tend to run more toe on the back than the front unless racing and you want lift off oversteer. As it has a greater effect on the front.
