Lottie
The Duchess
Tools required:
6mm Allen Key
13mm Spanner
10mm Socket
Tegiwa Brake Stopper Kit:
Locate the two bolts which need removing (highlighted by the red arrows).
Using the 10mm socket remove both bolts:
Insert the Tegiwa metal plate underneath the OEM plate and insert the two bolts.
Tighten using the 10mm socket.
Take the long bolt and screw on one of the nuts until it is about 1/3 from the top.
Insert the long bolt though the hole on the Tegiwa plate.
Screw on the remaining nut at the back.
Push the bolt through so it is just touching the Brake Cylinder.
Insert the allen key in the end of the bolt and tighten the two nuts against the Tegiwa plate using the Spanner.
Job done.
6mm Allen Key
13mm Spanner
10mm Socket
Job done.
