Got to be one of the cleanest ep3's around?!!
Cheers Chris but I doubt it is, probably far from it, but I do try!
A bit of a bigger update to explain where I'm at....so the Front Lower Arm Bushes (Front) were replaced with the Powerflex Purple Series bushes as previously planned.
I managed to get a Genuine Honda Clutch Kit on sale for a good price prior to getting the bushes done so booked this in to be done at the same time. It was getting very hard to change gear when in VTEC and from the paper work I have I'm not sure it's ever been replaced.
While waiting I was told that when they removed the Driveshaft part of the bracket for the Half-shaft fell apart as it was only being held together by the bolt! The oxidisation on the break shows that it wasn't new.
Unfortunately on the day we were unable to source a new part so for the time being it was put back and a washer used to hold it together. I jumped in to take her home but as I pulled away the Engine Management Light came on! Plugged in my ODBII reader when I got back and it displayed the code P0325 - "Knock sensor 1, Circuit Bank 1 or Single Sensor".
Gave the garage a call and explained what had happened. They said they checked with their reader once the job was done to make sure everything was ok and had nothing come up. They said that when I come back to get the Driveshaft sorted they'd have a look at this too.
Managed to source a used Half-shaft for a good price but when it arrived I wasn't happy with the condition. There was a fair amount of play and it didn't rotate as freely/smoothly as I'd like, seemed like the bearing was pretty worn to me. I made a complaint and a new one was sent out to me which was much better.
Got back down to the garage who fitted the new Half-shaft without any trouble and also connected their reader which displayed the same error code & message that mine had. Obviously I never had this problem before which leads me to believe that the Knock Sensor was damaged during the clutch install as I know this can happen pretty easily with them being so sensitive. Not particularly happy but I'll get a new Knock Sensor which will hopefully clear the light. Until then I'll just have to keep the driving to a minimum.
