Definitely knocking from the front??
My rear ARB drop links knocked like fook when they went..
I know what you mean I can't stand any suspicious noises, they get on your nerves I had an MG ZR 160 before this talk about noises and rattles. Didn't have a problem with the head gasket which is the major common fault just everything else, the most annoying car I've ever owned. Put up with that for over 2 years. You'll get there mate joys of motoring:lol:
Need longer camber bolts http://www.cplracing.co.uk/products.php?productid=127Oh i am also experiencing uneven wear on the inside of the front drivers side tyre. Can i adjust camber without camber bolts? It only needs to go 0.5 of a degrees?
Did you refit the spring 'socks'/covers to the lower part of the spring? The tighter coils in the spring can knock together, these covers stop the annoying noises .I have this exact same problem mate had it for 11 month since i also lowered it 35mm, knocking on left side front when i hit a dip or uneven road like a clunkin metal on metal sound, we are beginning to think there the wrong springs as there also moving about in the housing as they should never do. Im also stumped.
