Hello everyone,
New to forum, just saying hi and some info on my car.
James
Return of the wide boy!!
Tial Blow off valve
Garrett T3/T67 HO
Awesome welds on the Full Race manifold
Full Race Traction bars + engine brace
Golden Eagle vacuum manifold
Its all being tuned on 12-18th November by Owen Developments so not long.
Engine Spec -
Benson sleeved 83mm B20 block
89mm Benson balanced and micropolished crank
CP 9-1 pistons/rings, Eagle 3/8 rods, ACL bearings
New OEM oil pump, new pick-up, new waterpump
ARP head studs and Cometic head gasket
New SuperTech valves, dual springs and titanium retainers
B16 VTEC head with 3 angle valve job, new seals, surfaced, all done by
PortFlow
CTR intake and exhaust cams, AEM 5 bolt cam gears
New STR fuel rail and new 1000cc RC Injectors
Edlebrock Victor X with stock throttle body, sensors and vtec selenoid
Oil pump adaptor with ls/vtec line in place
Distributor with new wires ( being changed to coil pack)
New timing belt, harmonic balancer
Brand new alternator
Quaife LSD
Driveshaft shop stage 3 driveshafts
SPA gauges
Motec M4 pro ECU
James
James
Tial Blow off valve
Garrett T3/T67 HO
Engine Spec -
PortFlow
Quaife LSD
SPA gauges
Motec M4 pro ECU
James
