Just... 3 things.. If they're hub-centric; are these the bolt on spacers 'that bolt to your existing hub' then the wheels mount to the spacer? If so, that's not meant to be the safest way to space (apparently) - especially as you'll be tracking yours. Other thing is, if they're longer replacement studs - which is simply a case of replacing the existing studs for longer ones; this is the safest way apparently - but it's not a case of simply replacing OEM, IF facelift hubs are like PFL hubs... there is no space to remove the existing studs due to the bearing behind the hub face - so you need to remove the whole hub (ballache).. I'm sure, if this is the case, TGM will do the job - but it might be prudent to get these done whislt its on the ramp for suspension... BUT if it's all too much for you... I guess I could take your Volks off of you. All of that is true BTW, and I'm jesting about the RAY's.
