Happy days mate thanks for all the advice and inputs! I Will do now worries about that!! catch up soon mate look forward to seeing and hearing of new updates!:-D
Bad feedback !!!!! They're 2 lumps of metal, just as all the others are.
Are you talking about clutches?
I can assure you that you don't want an poorly balanced plate attached to the crank of your engine. If you think your front wheels wobble at 70mph on the motorway when they lose a balancing weight, imagine what the clutch would be like at 8,000 rpm.
As 4kas said, Exedy will be fine, but steer clear of the F1 Racing clutches.
They are cheap for a reason, there are quite a few that have caused issues because the plates are poorly balanced and I had the pressure plate deform on mine when I was running the stage 3 kit. On a heavy duty clutch the pressure plate should not deform, especially after 4 weeks and only 1,200 miles.
