You will see them on the outer edge of the disc near the hub. I'm sure Honda will supply you some new screws at an unholy rate if you really want them, failing that, your wheel will keep the discs on anyway.Cheers, where are the screws for the discs?
Can I get new ones too?(Screws)
You will need a impact screw driver
You will also need a piston rewind tool for the rear brakes. Its an easy job, worst part is removing the disc retaining screws which always seem to seize up.
I tell you what, if you want a hand you can borrow my rewind tool if I can take step by step pics for a guide?
Thanks, but I was going to go to Northampton for a friend to do them.
I could always pop to yours if you fancy fitting them for beer / cleaning tokens? :smt041
