moNoKnoT said:Noticed this the other day and now it does it all the time, I think its coming from the o/s suspension but not sure which one. Is this common on an 04?
- Kevin.
going to get mine in this week to have it looked at...............chippyleigh said:If it's not engine mounts, then it is probably the steering rack, common fault is to creak when you "take up the slack".
EmmaT said:Hi
Mine is at the dealer today to have a similar squeak / creak investigated. The noise is apparent when pulling away (just when you get that bite of the clutch / throttle) and then when I slow down to stop and is outside of the car. They suspect it be the engine mounts but I wonder if it's a suspension problem. This is a completely different noise to the "starter motor" noise mentioned in a different thread (because I get that too when it's cold). It's damn annoying :roll:
EmmaT said:EmmaT said:Hi
The dealer couldn't locate the cause of the noise. It's definately not the suspension or engine mounts. It's a case of having to live with it unless it gets louder. Hope someone else has better luck :roll:
