Mate, it's just an oil filter - and changes like any other; whether it's Mugen, Hamp or the OEM it just screws on and off - and should be firmly tightened by hand only.
- Drain the sump
- twist off old filter
- lubricate threads and rubber o-ring on new filter with new oil, then screw it on.
- replace sump plug
- fill approx. 4 litres of new oil then use the dip-stick as a guide to ensure correct oil level.
Once topped up; replace oil cap, check for leaks, wipe down rocker. Job done.
If you're unsure as to what you're doing, have someone in the know perform the oil change with you - otherwise get a mechanic to do it.. It's a £20 job... If that.
- Drain the sump
- replace sump plug
