FL5 Fuel gauge
When you put in the 40 litres what was the range showing after refuel?
My range isn't very good at all, but I thought it's due to not being able to fill the tank fully.
Just to let you all know I have removed my fuel pump and found the sender was not set correctly so I have adjusted mine and will see what happens
Just to let you all know I ran my car down to 0 then re fuelled after adjusting the float level in the tank and got 41.5 litres in so it has improved
At some point I am going to adjust it again to get it perfect.
Honda have clearly not set this up correctly
Good luck trying to get Honda to do something as even now I have come up with a fix they are still not interested.
When you take your car into Honda they need to lower the float level the manufacturer spec for lowest setting is 17mm I would lower it down to 10mm
I have just re fuel again got 255 miles from tank full
Re fuel with almost 43 litres so I am now happy with mine.
263 miles Dte after fill up
I suggest everyone take there car into there dealership and ask for sender to be removed and checked.
I contacted Customer Service asking for help they have done nothing to compensate me.
Spoke to Dealership and again don’t want to help!!
I have fixed the problem and Honda approach is disgraceful.
I took it into the dealership as well and they were able to get it checked out, I filled up 2 days ago, I had 15miles DTE, 11.5 gallons and got 290 miles for a full tank at 24mpg. That equates to 12.08gals (45.73 liters) I'm happy with this number, much better than the 10.1gals (38.23 liters)
they adjusted it yes, i told them to check there first because you found that being the issue. I do, however, know the head mechanic at the dealership I took it too, so it was easy for me to recommend where they should start.
