Yesterday I decided to give my headlights a bit of TLC. Baring in mind I've got a 9 year old car, the headlights were starting to look a little worn. The Offside headlight was particularly bad and was starting to get quite cloudy and it had a greenish tinge to it, as illustrated in the following pictures:
First job was to apply a bit of eye shadow to protect the paint work from the next step
Then I went over the headlight with some soaked 1500 wet and dry paper. I decided to go with a very fine grit as this was my first time doing this, so I didn't want to hash it up too much. After a couple of passes with the wet and dry, the headlight had seen better days.
I then used the G220 and did a couple of passes with a Megs polishing pad and the No.80 speed glaze:
This didn't do anything to the surface, so I didn't bother taking any after photo's.
I then did a couple of passes using a cutting pad and Megs No.83 This is my most aggressive set up (or so I thought).
This was the results after 2-3 passes
I could envisage this taking a hell of a long time, so out of desperation and remembering TypeGRRR's thread on DIY paint correction I gave the Autoglym SRP a go on the cutting pad.
After a couple of passes, I was quite surprised with the results. The SRP is a lot more aggresive cut than I had imagined.
Overall, I was very pleased with the results.
Having looked at he lights again in direct sunlight, there is still some light swirling on the surface. This will buff out quite nicely with some Megs No.80 on a polishing pad I should imagine though, so I will do this when I have some spare time.
I also gave the N1 a quick clean up with some autosol metal polish, so of course I took some obligatory pictures:
and finally, some randoms...
Thanks for looking.
