So wrote my post and for some reason my iPad and this forum didnt get on so I'll write it again :lol:
This is my BMW E38 728i; 2000 X reg, bought in Sept 2012 and it's a Sept 2000 build Bought it with just under 99k miles; it's just ticked over 100500 recently.
Finished in Aspensilver metallic with very recently refurbished 18" Style 32 alloys by Stevie at Wheelrite; Chorley:
A shot of the very straight forward engine bay:
Just replaced the OEM intake with a K&N Gen II 528i intake & currently adapting a custom cold air feed and shield made which I'll fit ASAP so will update pics then (OEM intake had a hole in the bottom (looks like it'd been forced back into position or it was leant on etc...) Was causing erratic idling issues; have tried to source a 2nd hand one but had 3 and sent 3 back as they were damaged even though they were sold as 'immaculate'. Always the case with eBay! As I dont do many miles with working from home economy and/or power loss hasnt been an issue (and havent noticed a drop in either TBH)!
Everything as its stands is OEM and really the only things ill be changing to soon will be a front upper strut brace; Eibach lowering springs when I replace the front shocks (not needed yet) and I may go for the H7R HID upgrade kit from HIDS4U and possibly some later style LED rear clusters. Will also be getting the gear box & filter changed but needs to be done by a specialist as it's not a straight forward job & has to be done as certain temps etc... :roll: Probably going to get a stainless cat back system made for it too to let some of that straight six burble out more
I've had a lot of work done on it since I bought it in Sept 2012 (suspension stuff (rear end overhaul with KYB springs and Boge shocks plus new top-hats), a few oil & oil filter changes, new front tyres, alloys fully refurbed in sparkle silver (stripped, acid dipped, powder coated and sparkle lacquer finish), new diff fluids and plugs, brake overhaul (Brembo discs all round; EBC Ultimax rear pads, EBC Redstuff pads upfront along with HEL stainless brake lines)
Just replaced the rad a few days ago as well (small hairline crack appeared under top hose connection) so sourced one through General Traffic for £85 Took it to my pals garage and we got it swapped over, refilled and bled in just over an hour
All work done by Stevie @ Grinspeed; he's alright, gets the job done etc... :lol: Much better at snapping tools and getting angry though :twisted:
Car is now in with the bodyshop for the following:
Sounds a lot but everything (bar the sill repair) will come in around the £200 mark (only small areas to be sorted thank god) and I reckon the sill repair will be around another £200 (fingers crossed)
Got some pics re the tin-worm eating away at the sill! Appears that it's had a bump but my pal at the body shop & I think it's been spun at some point as the dent is parallel to the sill and about the right height for a curb!
OS sill:
It's getting cut out and a new plate welded in right across the sill and will be seam sealed/wax oiled etc...
Will have it back Saturday/Sunday afternoon hopefully
Other than that the cars solid and runs like a dream :cool
- Rear boot lid rust patch to be removed and resprayed (as well as a small patch under the boot catch to be removed and resprayed)
- NS wings to be resprayed due to small rust spots appearing (havent broken through the paint yet)
- NS wing mirror area to be resprayed as small rust patch has appeared under the wing mirror cowling
- Front OS wing to be resprayed (same issues as NS wings)
- Rear OS door to have a small patch of rust removed and resprayed on the very bottom corner
- OS sill at the rear has rotted through so that needs stripping and a patch welding in and then seam-sealed
OS sill:
