So getting the Milltek has kind of pushed me to do other stuff now while I have been on my days off, so got on the phone to the local Mini dealership and priced up the Aero grills, which were the same price as Mini Direct on eBay. Once they said they could get them the same day after 4:30 I ordered them, along with the JCW gear knob too
Didn't realise the lower part was as much of a faf as it is to fit it, the top section is already fitted as I never fitted back the original grill on properly, so just finished putting the fasteners back on and done.
Due to the Aero grill being part of the kit for the Aero bumper, it doesn't fit the standard S bumper without modifying it first, so had to trim off excess plastic with the dremmel to fit.
Also got the bits to do the airbox modification as well, swapping for a cone filter as apposed to a panel filter.
Dropped my wheels off as well to be powder coated so the centre caps are ready to go on as well
Gearknob done
Can't beat the feel of a good knob
Blacked out the chrome S grills on the side wings, did them a bit ago with Plasti Dip but came off, so tried some stuff from Halfords and it seems better, used it on the petrol cap as well and it seems to last.
Modified the original air box to go from a panel filter to a K&N cone filter, many have done it and it's easy enough to do.
Only way you can tell is where I have riveted the connector for the filter on.
Inside the box, also put some draft seal stuff in between the plate so should all be sealed.
There is another part to the mod where they put a larger hole in the box on the secondary feed of cold air coming from the cowl panel but may try that at a later date...
Got the grill fitted but not got any daylight pics so will get some soon, not a bad days work
Sent from my HTC One M9 using Tapatalk
