I've had a look at the seat belt rail this afternoon and I think a plate could be made to go across both bolts and the bar could run right across the floor space.
To strengthen the plate fixing to the bar, there could be a small section to triangulate the fixing points... bit like this.
I spoke to Mick the other day at work and he had a looky at the car and the seat rails points.
After much chin-scratching, muttering and poking about he says that the bar is possible but to maximise the strengthening potential it would run right across the floor space i.e. where the rear passengers feet would be.
Mick is not convinced by having the bar running right up to the rear bench panel as the deflections needed in the bracket work would prove too great an area for flex to occur.
He would rather go for a bracket to fit across both seat belt rail bolts and then have the bar fit into the brackets using countersunk bolts or heavy duty removable cotter pins so that you could take the bar out if needs be.
Question that he asked. Do the seat belt rail bolts go straight into the chassis or do they rest on a small piece of panel?
If it is a direct bolt in then he is happy to do it. We did not have time to remove the plastic trim that goes around the seat belt rail to have a look as that section of plastic runs right up the inside of the rear space. We envision that the brackets would fit on the outside of the plastic trim as long as the mounting points are stable.
that's spot on mate.. I'll see what I can do. A job change for me means that I may not be able to link on with Mick straight away. I'll keep on it though.
