Is there any way of getting the new version for ''cheaper'', Honda charge the earth!
Take it out, sell it on ebay, get a decent headunit and tom tom
does anyone know how to install a new disk to the unit?? i think mine needs a refurb due to the disc error but im playing a copied version in at the mo, thought if i re-installed the orignal it may work??
any ideas??
thanks
Just done some digging since your post and found that you can force the sat nav to reload an earlier disk. Ive done it and its solved my disk reading error. I think it was because of the copied version.
Also where i found this, people where cleaning their disk lens themselves and finding it would sort the problem out, one way involves wrapping a wet wipe around a ruler, putting it in teh disc drive and moving it side to side!! ha seems to work for some!! have a look if it may help you, it includes the force download at the bottom,
http://www.howtomendit.com/answers.php?id=68955
OK, the official Honda method for forcing sat-nav to reset to older disc is as follows:
1. Start the engine.
2. error message appears on screen with old disc inserted.
3. Push 'MENU' and 'ZOOM DOWN' switches simultaneously for 2 seconds.
4. Screen turns to SYSTEM LINK page with a fanfare.
5. Press 'NEXT' switch (opens car staus page).
6. Press 'NEXT' switch (opens yaw rate page).
7. Press 'NEXT' switch (opens diagnosis menu page).
8. Select 'UNIT CHECK'.
9. Select 'FORCE DOWN LOAD'.
System will now start to download the old operating system firmware from the old disc, showing progress on a green bar gauge.
When finished the unit should be able to be started normally.
