The main thing I hear from friends when asking if they use V-Power is "well I tried it once and it didnt do owt different".
To me this normally means one of a few things, or sometimes a combination - either the ECU is still trying to figure out there has been a change and is still fine tuning the ignition timing or fuelling, the car is not driven hard enough for the driver to really notice the performance benefit, or the engine has been poorly maintained over it's life.
We are talking in terms of efficiency. When an engine is described as being efficient, this isnt nessecarily to say it doesn't use much petrol. The term efficient is really a ratio between chemical energy in and kinetic energy out.... How much Energy can be produced from a specified amount of fuel.
We all know that almost all modern engines are littered with transducers/sensors which send signals in the form of a voltage back to the ECU. The ECU can process the voltages (normally between 0-1V) and is programmed to make changes elsewhere if these signals are not at their optimum. The system works the same as a PLC-type system where the variety of data inputs determine certain data outputs.
If you consider that for the ECU to change a certain setting, there are quite a few stages before an improvement can be felt. The engine runs -> sensors/transducers produce voltage -> sensors sends signal back to ECU -> ECU processes data -> sends signal to alter fuelling/timing etc -> fuelling/timing physically alters -> sensors/transducers detect the change -> signal sent back to ECU .........And so on. The cycle is continuous from the second the engine runs to the minute it is turned off. If V-Power is put into the tank after the car has been running 95oct fuel for some time, the ECU will start to recieve different input voltages and will try its best to make changes elsewhere until it recieves values closer to its' optimum. It is only when this optimum is reached that the engine will produce more energy than it did previously. I believe that it is these optimum parameters which are altered when an engine is remapped alongside the AF ratios at certain RPM ranges.
Not to mention the added benefits of the detergents which are used in V-Power which cleanse the combustion chamber and burn cleaner than conventional fuels, helping to keep the build-up of carbon deposits to a minimum.
Oh and BTW, no I dont get any money from shell for saying this.
