N77 said:I thought the smaller the offset the closer it was inside the wheel arch ?
Mine are ET43 so my understanding was if they were under you could use spacers to correct it, if they were over you couldn't ?
Carl
kamion said:So an ET40 would be better than ET48? (That is if we go by Funky's description).
N77 said:The original offset is 45 so you will need the closest one to that as possible. The PCD is 5x114.3 (Its the measurment of where the holes are located as far as I am aware)
Yep they are that expensive which is why I went for KEI, look the same but I got my set for less than 1 wheel :lol: The quality is second to none though
Carl
Friendy said:Did anyone get a definate answers to the off set. I thought 48 would make the wheel closer to the outside of the car and a 43 would make the wheel closer to the suspension strut.
hovblackctr said:CTR offset is ET45
ET48 will make it closer to the suspension strut.
ET42 would make it closer to the outside wheel arch.
kamion said:http://www.1010tires.com/WheelOffsetCalculator.asp
Friendy said:How far away from the 45 can you go before they stick out of the arches, 40, 37?
