what i mean is that the bmw are notorious for getting that gunk on the oil filler cap on the inside, condensation from short journeys. i didn't mean that you'll get head gasket issues from them old boy.
if its creamy water then its head gasket, but if its just a little gunk on the cap then its just condensation mate, Clean it and let it warm up to temperature!!
Just checked the coolant, and it is low, very low! Though I have no idea when it was last checked... I am about to fill it up but starting to fear the worst! Does anyone know how much a new head gasket is likely to set me back?
get a compression test done before you start fearing the worst.
with the cold weather people have been having problems with the header tanks cracking, or connections between pipes cracking, corroding etc, so you might have a hairline crack in the cooling system somewhere.
Continuing from the sound advice of Rossy and Chris, if it fails a compression test, to be honest a new gasket is not likely to be the easy fix for the issue either.
Get is tested first. Then look at the options. If the head is warped, you are looking at skimming or replacement.
sounds like your having a bit of a problem, does sound like head gasket to me , which is very suprising , but im no qualified mechanic as for the aem have you considered getting a hydroshield for it?
