Everything that's been done to the car:
- Tie rod ends replaced with new fresh OEM babies.
- New drive shaft boot as original had split.
- New near side front drop link as bust (will replace other after pay day)
- BEST MOD EVER - driveshaft heatshield taken the F*CK off and rattle gone!
- Valve clearances done.
- D2 lower control arms fitted (not one for cheap ***** mods, but got these for barely anything thanks to my mate Aldo so got them fitted and have read they are fine anyway compared to their camber arms and coilies)
- Beaks Tie Bar fitted.
- OEM rear ARB bushes replaced with SuperPro poly bushes.
- Front control arm OEM bushes replaced with SuperPro poly bushes. Castor adjustment ftw :wink:
- Buddyclub P1 Racing roll centre adjusters fitted
- Buddyclub P1 Racing rear camber arms fitted
- Buddyclub N+ coilovers fitted
- Full geometry setup
Some pictures of how the car sits now and picture of the rear with the LCA's and tie bar:
The car is now like a go-kart, honestly. It's effortless awesome handling. The steering feels so much better with the SuperPro poly bushes. Stevie did say before I went down that the castor adjustment made a huge difference over OEM steering feel as the EP3 I think is a little vague and lifeless. Regardless of speed or corner type, the steering just feels more solid and steady even at high speeds. It's hard to explain but feels so much better.
The car is alot stiffer now, just feels all round much more planted. The only bad thing I can see is that I got alot done at once, so I can't see what difference exactly specific things make. Like the RCA's and poly bushes, if I had both fitted 6 months apart I could say differences each make, but having it all done at once. All I can say is that it works awesome together and the car is ridiculous in bends now :-D
Now, geo specs :twisted:
Front:
Camber = -1.8 degrees
Toe = 1.0mm Total Toe Out (0.5mm per side)
Rear = -1.0 degrees
Toe = 1.0mm Total Toe in (0.5mm per side)
