HASNIC said:Very very good ECU and they are a complete standalone unit rather than a modified stock unit and come in around £1000 ish.
They offer a bit more flexibiltiy than the Kpro and are based on a Gems ECU.
Mike (typerkid) is running one on his DC5 :wink:
HASNIC said:Very very good ECU and they are a complete standalone unit quote]
Are you sure its a standalone unit?
I was going to go for one before i went for Kpro. It would have to be hooked up to your existing ECU for the Air con and other electrical to work, abit like the Unichip.
Awesam said:HASNIC said:Very very good ECU and they are a complete standalone unit quote]
I was under the impression that it was a standalone unit in the sense it controls everything itself to do with engine parameters and doesn't need the stock ECU to do that but i have read there have been Aircon issues and things like coolant temp guages not reading so having to put a new sensor in etc.. with it.
I never really looked into the AEM, but from speaking to Mike it seems a step up from the Kpro in flexibilty/functions terms.
N77_CEJ said:The Kpro is alot better for our engines I have been told as they have more maps for each cam angle etc... where as the AEM doesn't.
At the end of the day whats better at running your car than a standard ECU, this was the reason I think that Hondata choose to modify the existing ECU.
The AEM is a very good ECU though and is used on many other applications but for me I prefer the Hondata as they are focused on Honda engines.
Carl
JonCTR said:N77_CEJ said:The Kpro is alot better for our engines I have been told as they have more maps for each cam angle etc... where as the AEM doesn't.
Carl
Yes, I think Doug explained that the number and/or resolution of the mapping points was much greater in the Hondata than AEM. AEM has real time mapping, but you only have to wait less than 10 secs to upload a k-pro map anyway. The number of new maps coming out from Hondata for various cams and headers looks pretty impressive now.
Jon
tp said:Shock horror its crap! :lol: :lol: :lol:
simonprelude said:The most important part of an AEM set up is the tuner, if the car is only making stock and it has mods then I would suggest gettg someone better to tune the car.
I have seen AEM tuners get 10-20 % increases out of a stock car, so with mods if done properly then there is no way that you will only get stock results.
tp said:[If you were binning/stripping for racing maybe the AEM is a viable option, but then again I would still probably lean towards the Kpro or maybe a high end stand alone motorsport ECU that has a track record.
typerkid said:tp said:[If you were binning/stripping for racing maybe the AEM is a viable option, but then again I would still probably lean towards the Kpro or maybe a high end stand alone motorsport ECU that has a track record.
So you don't call a AEM a motorsport ECU then Paul...
How come these have been used in F1 cars in the past then :?:
