S2KIP's S2000
Some more pics:
It's getting posted today, just have to work out if I can fit it myself or if I need to book the car in for fitting.
As many know, the S2000 comes in GT or Roadster, the GT benefits from having a hardtop. To convert a Roadster to have a hardtop isn't just as simple as buying a hard top and putting it on, there's a few things you need to buy/do which aren't as cheap as you'd hope.
  • Hardtop itself, typically around £600
  • Fitting kit, I paid £300
  • Bolts for the fitting kit, I don't think the ones already on the car work
  • Wiring loom for the rear screen (I don't have it)
On top of this there are a few bits of trim you either need to change or cut. I decided on cutting mine as when I come to sell the car I preferably want to sell it with the hardtop included.
I wasn't sure on how to do it, but without reading any guides I set upon having a go myself. How hard could it be I thought.
I fitted the kit to one side to have an idea of how it sits and what I needed to cut.
With the trim back in place you can see where it would foul the hole for the bolt on the hardtop. In addition, due to the way the mounting kit sits, it blocks the trim from being put back on correctly.
It's pretty easy to spot what needs cutting:
I needed to get a new tool to allow me to cut the standard trim, this will do nicely:
Let's get that trim chopped:
Test fitting, pretty much got the cut right the first time. I didn't fancy spending too much time cleaning it all up on the edges as it's well out of sight when on the car. Looking at the pics though I may get some sandpaper and tidy it up one day.
The passenger side has part of the loom for the heated screen so I had to chop a little more off:
How it looks all back together:
Took the door card off to sort out a small rattle so managed to snap some pics of the speaker install.
Drove to Sheffield this morning to pick up the hardtop.
Fits well and the colour match is good. :)
Not really. Drop it on, twist two handles behind the seats and do up two latches at the front. Job done.
I was going to keep that hardtop on for a week or so but I didn't expect 18 degrees and sunshine today, so I cleaned the car and then took it off followed by a drive around Coopers Hill/Birdlip.
Brake pedal has gone soft so I need to figure out what's gone on.
:lol:
Sadly not, think I posted a few pages back but it's a little OEM Honda one:
I'm sure to feel the difference in downforce through mid to high speed corners. :^o
:lol:
One in the pic is a veilside one
I replaced a bit in the engine bay today. No idea what it's called!
Before:
After:
Using Tegiwa bolts as they are cheaper than Honda and with them being anodised they shouldn't rust.
If you've got an S2000 then check this strip as it was quite rusty!
