I finally got around to removing my bumper and headlights to free my LED sidelights which had fallen out of the connectors and into the lights. After doing a spot of research on the DC5 forum it appeared that I had a fair bit of work ahead of me, however I was given an initial false sense of security as the bumper was actually very easy to remove.
Taking the light off was not so easy unfortunately. I knew where the bolts were and I knew one of them was difficult to get to, but just how difficult was not apparent until I got the bonnet off. Turns out my extension on my ratchet set was not long enough, so I had to quickly nip down to B&Q and pick up a new ratchet set to get to the last bolt
. When I was trying to get to the last bolt, I had to remove some round thing that appears to be connected to my HID's ballast. I thought it could have something to do with the airbag sensor, so I was very carefull when taking it off. Anyone know what it is?
Anyway, once my light was off, I gave it a bit of a shake and my lost LED's appeared! woot woot! When I put them back in the side lights however they blew the fuse as the body is metal and it was touching the contacts. I decided to wrap some electrical tape around the body of the LED so there was only minimal contact between the LED and the light holder. This solved the problem after testing it with a borrowed fuse from the hazzard lights :lol:. The LED's look much better and compliment the HID's nicely.
As the bumper was off, I took this oppurtunity to slap on a mesh grille infront of the radiator to hopefully prevent any stones flicking up and smashing through the rad.
Before:
After:
Fitting was very easy, it was just a bit time consuming cutting the mesh. I attached the mesh where I could using tag ties and fortunately there is enough points to make it a nice snug fit:
As the bonnet was up, I also took the oppurtunity to take some snaps of some stuff I've aquired in recent months.
Carbon porn:
Spoon Oil Cap
