That was one of the most scary drives I have ever had....and don't want to be repeating that in a hurry!
:lol:
Anyone that has driven Knockhill will know just how bumpy the track is and with a car running the power we have and as light was all over the place. You hit a braking zone then it would bounce around pull to the side then back end try and come round every time. It did make me brake very early to try and get the front end lined up for the corners but also lost me quite a bit of time. Put the power down and the front was lifting spinning up on the bumps!
It seemed a lot easier in the GTR last year as it soaked up the bumps a lot better but this was mad. Paul Hughes even snapped a front suspension strut with the forces of the un-even track.
It was pretty busy out on track again with about 25 cars out at once so trying to get a clear run without taking avoiding action from a big powered 4WD car bearing down on you at warp speed was also a bit of a problem but hey ho.
I got a better run in qualifying where we worked out I could do a couple of quick laps then have to back off or the brakes would overheat and fade.
Superbattle was a disaster where I couldn't get a clear track then when I did the car just felt really sluggish. I retired before the end only to find the front brakes had been binding and the tensioner bolt on the supercharger had snapped so effectively the drivebelt is slipping under load.
Never mind. Points are on the board and a few jobs...like replacing sheered bolts and brakes again and we should be ready for Silverstone in 2 weeks.
Effort award for the day must go to Paul Hughes and the Buddyclub boys.
After the strut snapping on the hairpin the car was dragged back and a hasty repair was made by cutting down some spanners and welding them to the strut after a lot of hammer abuse to try and straighten it. Not only that they lost a bearing from the driveshaft so improvised with the ring off another spanner with a socket jammed into it!
They packed the whole UJ with Lithium grease, wrapped it in a bin liner and qualified first then did the final to take the win!:twisted:
Best achievement I think is Dave Thorpe in his NA EP3. Considering its only basic I/H/E mods and about 230bhp he was running same times as I was with nearly double the power!:twisted: And when you look at some previous times to make a comparison you will realise just how good everyone was doing and the level of competition this year!
Paul West (tp) - Rotrex EP3 - 1:04.333
Dave Thorpe (DaveT) - NA EP3 - 1:04.357
Previous drivers:
Simon Miskelly DC5 - 1:07.723
Dixon Cheng DC2 - 108.099
Olly Crawford - Rotrex EP3 - 1:04.525
